Crankshaft problem advice needed!!!
I discovered yesturday that when my car is idleing i hear a screech noise now and then so i decided to check under the hood. What i came acrossed is that my crankshaft is not rotating all the time, it rotates around 1 time then stops for a second then rotates again. I was wondering if anyone knows what the problem might be and give me some advice on it. Also i checked my drive belt and underneath i felt and it was kind of dry and tiny chunks were missing which im going to need to change the belt but would this cause it? Let me know i would really appreciate it alot. Thanks
Jon
						Jon
- atlantamx3
ha
Haha sorry my mistake, it was the pulley at the middle of the engine, i cant remember what it is i feel stupid lol. Well its like in the very middle of the engine and is part of the drivebelt system so sorry let me know alright thanks lol.
						Ill take a picture of it and let you see
I'll take a picture of it so you can see and post it. Alright
						Crank
My mistake its my crankshaft pulley. It spins once and stops and spins once then stops and makes a sreech noise.  But while the pulley is not spinning the belt is still moving so it seems like its ok but i just wonder if there is a bolt i need to tighten or something. Let me know
						- ryanlindenberg
i think it's your water pump.  how many belts run on the pulley?  if it's one then it's your water pump(pulley has 3 small bolts holding it on), if it's 2 belts then it's the crankshaft pulley(has one BIG bolt holding it on) which isn't even possible.  i'd replace the water pump and both of the belts.
							CARDOMAIN WITH UPDATED PICS
Its
Its the crankshaft pulley it has the big drive belt and the smaller belt that runs one it thats closer to the engine. It has 2 belts on it. Could it be there is a bolt that needs to be tighten or i need to lubricate it? Well Jay if you want when i get payed Friday and you want to bring the headunit you can take a look if you want. Just let me know anything thanks.
