to all of you with remotestart on mtx need help with install
ok 2 things how do i bypass the clutch switch i know where it is but i need to know how to bridge the switch so i dont need to push in the clutch when i start. now the wire which is called the neutral safety switch this wire will tell the alarm whether the car is in park or neutral i am gonna hook it up to the emergency brake i just need to know where i can find that wire i know i can find it right where the e-brake is but it roots sumwhere under the steering column it will be much easier for me this way if anyone knows where that wire is can u please help me out thanks
95 Mx-3 GS [R.I.P.]
96 Mx-3 GSR [Sold]
97 Mitsubishi eclipse spyder [For Sale]
97 Saturn SL2 [Sold]
03 Corvette Z06 [Current toy]
98 Saturn SL2 [Daily]
http://www.cardomain.com/ride/2176731" onclick="window.open(this.href);return false;
96 Mx-3 GSR [Sold]
- neverenuff
Email me at redrm20@aol.com and I'll give you full info on wire location and colors.
- ovendenk
hey redrm26,
i've already bypassed the clutch fine, but would like to include the neutral switch. did you tap into that wire going into the ecu or what? could you let me know. email sent. tia
kevin (aka The Oven)
93 mx-3 GS KL-ZE with KL31 cams and properly chipped ecu
All mods are on my website: http://ca.geocities.com/ovendenk
MX-3.com Worklog: http://www.mx-3.com/phpbb2/viewtopic.php?t=48462
- neverenuff
ll I did'nt recieve the email but here is all the info needed. Use this info at your own risk myself nor MX-3.com will be held responsible for any damages that may be caused by this information. that being said here ya go hope this helps. make sure to test wires befor install althought these are rather on point. Also this is for a 93 mx3 not sure if wire location and colors change with year but if so just give me year and i'll check. here ya go.
12volts black + ignition harness
Starter black/blue + ignition harness
Second Starter
Ignition blue + ignition harness
Second Ignition
Third Ignition
Accessory black/red + ignition harness
Second Accessory
Keysense
Power Lock actuator drivers door
Power Unlock actuator drivers door
Lock Motor
Unlock Motor
Parking Lights + red/black dimmer control switch
Parking Lights - green steering column
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger - red/white 3 pin plug above fuse
Dome Supervision
Trunk/Hatch Pin - red at switch or light
Hood Pin
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm
Factory Alarm Disarm
Disarm No Unlock
Tachometer yellow-blue ac at distributor
Wait to start
Brake Wire green + brake switch
Parking Brake
Horn Trigger grn/red or grn/blk - steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
Interface Modules
MAKE : MAZDA | MODEL : MX-3 | YEAR : 1993
* The logo is registered trade mark of Mazda Corporate.
Copyright © 2000-2001 Directed Electronics, Inc. All Rights Reserved. Revised: 11 January 2001
This website is for the sole use of authorized DEI personel and it's participating installers and retailers. The information contained on these pages may contain confidential and privileged information. Any unauthorized review, use, disclosure or distribution is prohibited.
Second Starter
Second Ignition
Third Ignition
Second Accessory
Keysense
Lock Motor
Unlock Motor
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Dome Supervision
Hood Pin
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm
Disarm No Unlock
Wait to start
Parking Brake
Memory Seat 1
Memory Seat 2
Memory Seat 3
Interface Modules
