Klze engine prob
- shawno
Klze engine prob
I just bought a klze and the head code says kL-1A1 is that a true J- spec engine. And the wireing harness was cut in half so i need a new will the wireing harnes from the 1.8L fit on the 2.5L. And one more thing there was a hole in the oil pan will the 1.8L oil pan fit on the 2.5L. Thanks
You don't need the wiring harness from the KLZE, the stock wiring harness will do the job
lakersfan1
Before you dump it in swap the coolant neck sensors.... or else your fans will piss you off ALOT
- bmwm3guy
AGAIN, just search the site if you dont believe me.. its been covered too many times to count.bmwm3guy wrote:that is a KLDE, not a KLZE
KL31 101 and KL31 1A1 means a KLZE
KL 101 and KL1A1 means a KLDE
EDIT: If you still dont buy it, Ill take a pic of my ZE block to prove it to you.
Take a pic of it and post it up. What does the intake manifold look like? what cams does it have?
It is probably a klde, ford sent probes over to japan with klde motors. So the place you got it from is telling the truth that it is 100% jdm. But that doesnt mean it is a klze. It has happened a nice few times that people end up with klde's from engine suppliers that only get engines from Japan.
Black Magic
If it's a curved neck one, it still could be a klze with 200hp. We had one too, installed it, put it on a dyno and it had 175whp. Could you post a pic.
Bastian
Bastian
17 inch bba racings rims, apex lowering springs, laser muffler, boost steering wheel, mazdaspeed seats, black altezza's, testpipe, oh and a polished klze with an upgraded clutch and a kl36 ecu.
- bmwm3guy
If it says KL101 then NO, it is not a ZE. Plain and simple. Sounds like it may be a hybrid motor that someone threw together to try and sell as a ZE. I dunno, but I would be pissed.Black Magic wrote:If it's a curved neck one, it still could be a klze with 200hp. We had one too, installed it, put it on a dyno and it had 175whp. Could you post a pic.
Bastian
correction, i ordered a j-spec engine and it came with the ms8 curved necked manifold and it had kl101 and kl1a1 on the heads, i read somewhere on here that all that means is that it is the low compression ZE motor, with 9.2:1 compression instead of the 10:1, and has 190hp, instead of the 200hp, and i have this engine in my car and i can tell you for sure it is alot more power than the KLDE 165 hp engine.
You know the world is going crazy when the best rapper is a White guy, the best golfer is a black guy, The Swiss hold the America's Cup, France is accusing the US of arrogance, and Germany doesn't want to go to war
- 93-Spec-Edn
This was discussed quite sometime ago, but IanL proved there was such a thing and he even posted a website that listed all the mazda engines and their rating. I believe the lower compression ones had 187hp and were a lot newer in year. Anyone know where IanL is? havent seen him in a while.bmwm3guy wrote:low compression ZE motor eh?Somehow I seriously doubt that
isnt a KLDE a "low compression ZE motor" then? lol
92 mx-3 RS RIP | 95 mx-3 GS sold | 93 mx-3 GS SE sold | 95 mx-3 GS present
