Odd problem with car suddenly stalling out
my exhaust broke away from the precat wednessday and next friday i'm getting the exhuast all redone but today suddenly my car has started stalling out is this related to the lack of an exhuast or is this a new problem?
ProjectMx
My BP and AWD build thread
Cardomain
93 Mx-3 GS with bp and GTR AWD system
93 Escort GT daily driving
Cardomain
also it only does it till the car warms up so like the first 3 or 4 minutes then it seems to do ok
ProjectMx
Cardomain
Cardomain
- ktm_girl82
odd problem ?
have you checked your catalytic converter ? it may be clogged it would cause your car to stall out on you ? only a suggestion. . . or fuel filter
i'm 100% sure it isn't the cat cause my exhaust broke off at the flex pipe *see first post* and it isn't the fuel filter cuase i put a new one on around 2 weeks ago... but it could be the lack of a cat/exhaust... that is what i'm hoping... i guess i'll know friday when they put my new exhaust on
ProjectMx
Cardomain
Cardomain
My car was doing the EXACT same thing for a couple of weeks about a month ago. I did whole Seafoam and Deep Creep treatment, and it never happened again since. I'm not sure something got cleaned up inside and fixed the problem or not. I bought a can of Deep Creep from O'Reiley's, sprayed a half can to the throttle body/blade and drove around. Next day I used the rest and did the same thing. It's only $5.99 or something like that, so you might want to give it a try. You will see a lot of smoke and it looks like it's cleaning something. I also add a can to the gas tank. Right before oil change, I put it in crank case and drove around too. Never heard a bad thing about Seafoam product, so it won't cause any harm. Let me know if you find anything.
when you did this did you spray it just on the butterfly? or did you open it up and spray it inside the throttle body? I finally got the car back from the exhaust shop yesterday and it is still doing it today.. oh by the way got a 2.25" alluminum exhaust from the pre-cat back
ProjectMx
Cardomain
Cardomain
