what kind of bolt is this?
- MX-3 Money
I was taking apart my old k8 and i'm stuck cuz i have no idea what like of socket i need to use on this bolt. Its like a star shaped bolt and looks like it have 12 sides to it. its under the vavle cover, right next to the vavle springs and ther are six total. anyone know what socket i need to use?
http://img.villagephotos.com/p/2005-4/9 ... P_0008.GIF
http://img.villagephotos.com/p/2005-4/9 ... P_0009.GIF
sorry for the crappy pics.
1993 MX-3 GS 5 spd, KL-ZE swap, kl31 ecu, 110 amp alternator, Unorthodox Underdrive Pulley, SSautocrome headers, High flow cat, Pacesetter high flow cat-back, B&M shortshifter, Clear Sigs/Sides.
- Tunes67
Those are the head bolts. Use a 12 point 14mm socket (I think thats the size) or you can go to Mazda or Napa and request the proper socket.
Tunes67
PS - Also.. you may need to use a breaker bar (Big a-- bar with a 1/2" socket adapter) to get enough torque to break those suckers free.. depending on the condition of the engine.. if it was overheated.. could be a serious pain to get those bolts out.
Tunes67
- babyblueMX3
btw their's 8 bolts per heads..well on the kl at least..should be the same on the k8..
isn't 12mm ?? I really think it's 12
RIP 400whp ZE-T MX-3
- babyblueMX3
lol ok I thought you were sure..
I am 95% positively sure it's 12mm
they're only 2 kind of bolts like that on the engine and they are the head bolts and rods bolts..
rod are 10mm IIRC
rod are 10mm IIRC
- mrspanky79
jimishadow
- babyblueMX3
