ECU tag on 94/95 K8 ecus
papa roached
Post by papa roached »
i know the 92-93s are K801, whats the 94/95 ones?
IanL
Post by IanL »
In the UK:
'93 - K838-18-881A
'94 on - K857-18-881
These are without immobiliser - I don't think the American market got immobilisers?
Extra thick soundproofing in the boot (trunk) to quieten my stainless steel exhaust system :)
papa roached
anyone in the USA? thanks for the info man
