I would like to give some lucky basturd the chance to own probably the cleanest mx-3 that has ever been done......
The car has a manufactuing date of july of 1994.....this is an mx-3 gs with 130,000km original on the immaculate no rust or accident body with only 30,000km on the 2.5 v6 KLZE motor!!!!!!
mods include:
klze 2.5 motor with the kl-31 cams
millenia square runner intake manifold
klze ecu
phenolic spacers
magnacore wires w/ngk iridium plugs
custom cold air intake with k&n cone filter
custom short throw shifter
clutch master stage 1
fidenza 9lb flywheel
all red line synthetic fluids used
2.25 custom magnaflow exhaust with highflow cat
ground control coilovers with tokico blues
full 6 point cromoly roll cage(yes cromoly and $3000 my cost)
kvr crossdrilled rotors w/cf brake pads
2001 miata 16" wheels
6.5" infinity kappas in the frt and 6x9 in rear with infinitys basslinked sub
pioneer double din cd/cass deck
grey driver and passenger corbeau cr1z racing reclinable seats
corbeau driver and passenger 3 pnt harnesses with 4 mazdaspeed pads
momo silver jet carbonfiber wheel and matching shift knob
custom aluminum mx-3 pedal kit
oem mx-3 aluminum scuff guards
light grey door inserts
real carbon fibre dash kit
slim visors
tinted
autopage alarm with keyless entry
parts not installed but come with the car are:
oem side skirts
srd frt crossmember
srd nylotron shims for ground controls
srd shifter and extention bushings
srd member mount bushings
unorthodox underdrive pulley
klze straight neck manifold
camber bolts
The car has been repainted last summer by one of the best shops in Toronto and is painted oem mazda titanium grey metallic(gun metal). Car has been garage kept and never seen winter!!! I was told several times that it is the cleanest mx-3 ever(by looking under the car) !!!! come see it for yourself!!! BTW the lights r yellow because of the GTS headlight covers......
First $10,000CAD takes it.....
