Sorry for the delay everyone, New Years and work got in the way....
Motors have been weighted with oil and exhaust manifolds, But
No water,no flywheel, no Inlet manifold assy, no Auxiliary parts i.e.
A/c pump, P/s pump, tensioner brackets
Hope this solves a lot of the miss conceptions Matt..
wow, only 6 lbs difference, i think this needs to go in the FAQ
Parts needing installed: turbo kit from BB (if i ever get it), 9.0:1 CR Diamond pistons, 4340 forged H beam rods, C/J-Spec spoiler, Nissan red tops in KL rails http://www.cardomain.com/id/blazejeremy
yea, the difference in kgs works out to about 6 lbs
Sorry forgot to mention that the inlet mainafold and throttle body
weights in at 15kgs.
Matt
Thats 15kgs for a K8 one, having removed the KLZE one at the
wreakers yard ( Enuos 800 ) as i did'nt want to pay for it cos they
slug ya for the mainafold, throttle body and injectors.
I can say it would be 15kgs as well plus/minus a kg for a KLZE one.
