BIG motor
- papa roached
BIG motor
- fry_81
Re: BIG motor
ya? what about it? i got the same one in my mx3.
lol thats insane though, it almost looks like a typing error
Maximum power: 108,920 hp at 102 rpm
Maximum torque: 5,608,312 lb/ft at 102rpm
1994 5spd GS Parts Car For Sale 800obo. e-mail for details. fry_81@hotmail.com
Re: BIG motor
I'd like to see the turbo that thing uses
- fry_81
Re: BIG motor
lol ya im sure the turbo is the size of a garage.
- Franko
Re: BIG motor
I refuse to believe that actually exists... It makes no sense.. How is it so big? I mean, holy crap!
Re: BIG motor
HOLY $h!t . Over 5Million ft/lbs TORQUE!!! That would take like 10 years just to build let alone the tanker ship carrying whatever would take a tanker's entire cargo of oil to just fill it. Wanna talk about some pistons. That thing would never crack or bust!!!lol. But anyway that's truley amazing.
Ferrari Red w/silver Metallic 92' Mx-3 GsR: Blown 5 Built motors from my past project and am going to N/A for a while as I get use to Megasquirt for proper tuning then may boost....TT setups have too much lag and too low of a power output for the rpm range i sought....Single is better and may do that in future...New project is custom Alum Mani/ with 3-4" runners...NO ?'s about my previous setup I don't want anyone to waste as Much $$$$$$ as I did...listen to BabyBlue and the those guys and go with thier F/I setups
- mrspanky79
Re: BIG motor
its hard to believe but some ships out there have 2-4 of these motors in themOriginally posted by Franko:
War does not determine who is right, war determine who is left!
94 mx3 GSX Stroked Turbo'd and Intercooled
99 vitara 4x4
99 vitara 4x4
- papa roached
Re: BIG motor
wonder what the rebuild kit would cost
Yeahhhh... well
I saw one of those +20 HP "chips" on ebay for that engine.
- MX3-Freak
How the hell do you start that beast? Do you realize the power that is gonna be used to to crank it!??!?!
Stock 1995 RS - Creek Blue
Car Meanins:
Car Meanins:
If its set up the same as heavy oil power stations you would have a "black start" gen set (say 200 kw). This provides power (240 volt or 110 volt ) for the control circuit and start circuits etc. Once the main engines are on line the black start unit can be shut down. You'd also have decompressors on the valves so the engine can be cranked with no compression and then the valves can be closed to give compression and fire.How the hell do you start that beast? Do you realize the power that is gonna be used to to crank it!??!?!
