well.... will it? if so, i'm thinking maybe some alterations need to be made?
<small>[ December 19, 2004, 09:55 PM: Message edited by: MarkMoore ]</small>
will a mtx from an RS work in my GS
1992 GS/RS Mutant Automatic
- atlantamx3
Re: will a mtx from an RS work in my GS
NO, the bellhousing has a differnet bolt pattern.
I just read something very interesting on the Pt forum... As the sounds of it you "should"(not 100% ask jeff Jeske on Pt) be able to put the guts inside of the tranny. Or go find an escort for cheap and flip flop your gears to your wants!!! you should check up on that post...Very good info. I may change out my gears in my mtx trans.
Ferrari Red w/silver Metallic 92' Mx-3 GsR: Blown 5 Built motors from my past project and am going to N/A for a while as I get use to Megasquirt for proper tuning then may boost....TT setups have too much lag and too low of a power output for the rpm range i sought....Single is better and may do that in future...New project is custom Alum Mani/ with 3-4" runners...NO ?'s about my previous setup I don't want anyone to waste as Much $$$$$$ as I did...listen to BabyBlue and the those guys and go with thier F/I setups
