Intake manifold question
trentonsuncle@msn.com
Post by trentonsuncle@msn.com »
Ok guys i need some real help here. i took my intake manifold off and cleaned it then i put it back on and now my car will not start. its getting spark and everything. Do i ABSOLUTLY HAVE to replace the intake manifold gasket? people told me i HAVE to and others said i didnt. Would that cause the car not to start. Help me out guys
babyblueMX3
Re: Intake manifold question
Post by babyblueMX3 »
a leak can cause can make the car won't start..My suggesion is start checking for leaks..or did you forgot to plug something (like fuel lines) when you put the manifold back on ?
RIP 400whp ZE-T MX-3
Yoda
Post by Yoda »
Did you put the fuel lines on correctly? It is likely that you reversed the feel and return lines.
