is 10.817 a good time for the 1/8th?
Tyler17rose
K8 with CAI and muffler. <p>Clutch slipps and i have a clogged cat, sub and socket set cordless drill amp and school books in the car.
Mods:
- ZE, Mike seli 214 intake cams, Ported n polished heads, Interprep valve springs, DE retainers, rebuilt bottom end, toga main and rod bearings, toga hv oil pump, CZT 67mm tb, mbx udp, ported intake mani, SS headers, 2.5inch full exhaust, racingbeat muffler, highflow cat, megasquirt v2.
new toy, 86 TII rx7, JDM S5 motor/turbo, + alot of other goodies
Re: is 10.817 a good time for the 1/8th?
Heh given the excuses.., <p>if your curious a good rule of thumb for figureing thigns out is multiply a 1/8th mile time by 1.55 to get what it would be in the 1/4... <p>Yeah that would seem really fast for a clogged cat.. must not be very clogged
-torp.
I don't own a Mazda.
Tyler17rose
Where does this 1.55 number come from? <p>And I'm almost positive its clogged cause my car gets bad gas milage and sometimes stinks like eggs (ive been told cats do that when clogged
<p>Any other comments? What does everyone else run?
Mods:
i ran a 10.6 with the car gutted on my k8
93 Mx-3 GS klze swapped(sold)
96 Integra LS DD
91 Crx Si drag car
2.0L sleeved gsr block, forged internals, skunk2 valvetrain, HP racing intake manifold, Holset H1 turbo, 1000cc injectors, short geared lsd transmission, 3" turboback exhaust. 20 psi
96 Integra LS DD
91 Crx Si drag car
Tyler17rose
So 10.817 isnt too shabby? Sweet. I'm gona get a test pipe and take it back to the track. Maybe i'll hit 10.6
<p>Oh and this time i'm gona leave the tools at home!
Mods:
Nah if your smellin eggs its not clogged... no top end can be a result of a clogged unn.. yoru cat is going bad.. doubt its losing any flow. just get a new one or a test pipe
-torp.
Tyler17rose
Well i tried to get a test pipe today, but the shop wouldnt do it. They said something about a 10 000 dollar fine.
So i guess i'll just have to live with it, or save for a high flow cat.
<p>Anyone know where i can get a pipe? Cause i even asked them to make a peice of pipe with flanges the same length as the cat so i could put it in. They still said no.
Mods:
Most places shun away from that quite a bit.. the penalties is steep.. search around online or use a peice of temporay exsaust pipe and just use clamps out of the store.. they work really well.. its not welded but it still works
-torp.
