december 1/8th mile leaders
60ft 2.1 <-----natural born honda killer<BR>9.581 et<BR>74.274 mph
jeremy cline
95 MX-3 RS
The only BPT GTR MX-3 in Texas!!!
man iraq sucks!!!
95 MX-3 RS
man iraq sucks!!!
Re: december 1/8th mile leaders
2.131 60ft<P>9.124 1/8@ 77.83mph<P><BR>I think you will run a 14.5-14.8<P>if I look at my time slips
13.023 @ 105 mph
9.613 et<BR>2.345 60ft<BR>73.43 mph<P>stupid stock exhaust <BR>
93 Mx-3 GS klze swapped(sold)
96 Integra LS DD
91 Crx Si drag car
2.0L sleeved gsr block, forged internals, skunk2 valvetrain, HP racing intake manifold, Holset H1 turbo, 1000cc injectors, short geared lsd transmission, 3" turboback exhaust. 20 psi
96 Integra LS DD
91 Crx Si drag car
9.979 et<BR>73.45 mph<BR>2.431 60 ft<P>Beginner.......
The only time I got to run the car befor my turbo twisted the turbine shaft completly in half in two differt spots at the compressor wheel I ran a <B>PATHETIC</B>:<P>60ft @ 2.378<BR>330ft @ 6.649<BR>10.238 @ 67.87MPH et<P>When I took it to the 1/8th mile (knowing it was running MAYBE 50%) the turbo didn't spool 12psi till 3200RPM, at 4000RPM boost droped to around 10psi, then all the way down to around 6psi at 4500RPM. The car BARELY reved to 5500RPM which is where I shifted.<P>Now with the new VJ-14 turbo it's pulling MUCH stronger! It goes down the road slightly side ways due to the torque steer spinning all the way through 1st & 2nd with the Pro LX tranny catching up in 3rd.<P>I <B>GUARENTY</B> it pulls 9.0 flat to low 9's. Ran a 1/4mile stretch from a stand still start & hit 105MPH at the 1/4mile mark.
- Shady469
10.9 @ 60 4cyl SOHC<BR>On 17's with stock clutch, muffler, and some other stuff.<BR>this was at the beginning of last summer(hot as hell) and first time @ track.<p>[ December 06, 2002: Message edited by: Shady469 ]
B6T powered MX-3 - sold
Stage 3ish 03 WRX - sold
03 S2000 - current/ for sale
Sure it wasnt a 10.999 seems kinda fast for a sohc =]<P><BR>60ft 2.346<BR>10.625 et<BR>64.02mph
-torp.
I don't own a Mazda.
- Shady469
maybe a stronge motor? i'd like to know what the other SOHC are running...<BR>BTW first run was like an 11.8 against a CRX that runs 12.4's in the 1/4... I got him off the line though!<BR>and that 10.9 run i launched at like 6 grand(clutch was gone at that point). oh well, i'll try to post slips next time i run(hopefully with the B6T).
A strong motor? yeah like brand new and being -30c out side.
-torp.
