kyb struts
kyb struts
Has anybody ever heard of KYB struts, making a clicking noise, Mine do and i have checked for any signs of leakage in them and they still seem to work properly so... i dont know
				ProtegeSTS
				zytariuk
Re: kyb struts
It could very well be your sping coils hitting eachother
 . How low did you drop your car?<p>[ February 04, 2003: Message edited by: zytariuk ]</p>
							<img src="http://members.rogers.com/zytariuk/images/mx-3.gif" alt=" - " />
1992 Mazda Mx-3 GS - Beige metallic
zytariuk's mx-3 page (updated June 12th, 2003)
Re: kyb struts
I've heard that most progesive/ dual rate springs tick when they hit the point where the heavy rate takes over from the light one.  Never witnessed it though.
				sheller
Re: kyb struts
What kind of clicking noise are you speaking of?  When is it happening?  If it is when you are driving it might not be the struts or springs.  Try looking at your sway bar linkages.  If they are worn it could be causing some clicking sound.<p>Steve
						Re: kyb struts
What kind of springs do u have??  If you have other than stock, its probaly your springs moving around.  This happened to me when i had my intrax ones on my RS.  The perch's werent in the same seat point as the stock perch's were so it would move around a  tad bit..
My Cardomain site
						My Cardomain site
Re: kyb struts
Well the noise is a sharp click, i have intrax springs. I have only heard the noise in the winter and as of today its gone? It just suddenly stopped after annoying me for a 5 weeks straight. I'm still gonna look into it and it maybe the precher mounts, and i have looked into my sway bar linkage, i have ordered new parts for them they were like 60$ each side. I'll keep you guys posted but if anybodys got anymore suggestions i'm open to them.
Thanks a lot guys and gals
				davidosk024
Re: kyb struts
Clicking could also be your strut tops
maybe the bushings are worn
In
Eunos 30x, v6
KL-ZE, 2.5in exhaust, K&N intake
Unichip, LSD, 13lb flywheel, ACT2 clutch, NGK iridium Plugs, Top Gun Leads...<p>Goin In
Cams, Headers, TB, Extractors,
Bored to 2.8, Mazdaspeed Struts, Mazdaspeed strut tops,
Mazdaspeed swaybars, Eibach springs, Cusco Adj. Strut tops, Body kit, Altezza lights, Short shifter, Crossdrilled rotors and Calipers from AP racing, Braided brake lines, Braided clutch line, Mazdaspeed steering wheel, Mazdaspeed Leather shift knob,
						Eunos 30x, v6
Re: kyb struts
My friend mx-3 also has that problem we changed everything in the suspension except the table bushing and there's still a clicking sound. His running the same set-up has my pro lx 93 and i don't have any problem for my part. We have apex coil with kyb gr-2 strut on our car. Can tell you that the mx-3 has way more handling then my pro but then he has 17" wheel on.
