what turbo parts are used for th t3/t4 hybrid???
and also were the hell can i find a rebuild kit for a garrett t3 turbo... and would 2 inch piping be good enough for my turbo are should i go bigger ????
"get some!"
- babyblueMX3
Re: what turbo parts are used for th t3/t4 hybrid???
you need to be more specific..what pipes are you talking about..well first of all..you got the 4 banger or v6 ??? this changes the whole piping situation and size...
RIP 400whp ZE-T MX-3
its a manual sohc 1 .6 and i was referimg to intercooler piping.
"get some!"
Anything under 300HP I'd use 2.25" IC pipes. 300-400HP use 2.25" from turbo to IC, then 2.5" from IC to throttle body. 400-500HP use 2.5" IC pipes. 500HP+ 3" IC pipes. These are general guide lines, to get the best results you need to try different combinations. If you need to rebuild your turbo I'd suggest looking into a ball bearing CHRA that will fit your exhaust housing. Yes it costs more, but it will last a LOT longer and handle a LOT more boot. E-mail me if you'ld like me to see what I can find for ya.
- monty73741
instead of turbo why not the bpt\bp
Jason Danaher
Please Help Support MX-3.com
