I have been reading so much about turbo setups recently, and i have come to 2 concepts very often. One is the piggyback system and the other is stand alone fuel management. I have no idea what exactly these do, but i know there are several cars that have both and have to do something with the amount of fuel injected in cylinders, and some have just one of them. Also i was reading that one of these controls the timing of the engine, the thing that doesnt make sense to me is that, the timing of the valves are controlled by camshafts and not electronically controlled, so how can an electronic device control the timing.
oh and one more thing that concerns me is boost controllers, the boost created by the turbo manifold does depends on the revolution power created from the exhaust side of the turbo and the size of it, so how can a boost controller take control of the boost; can it increase the boost on a small size turbo. I also need some explanation on what T2, T3 or T4 turbos mean and what defers them from each other; is there any other kind of turbo bigger than this that i dont know of ??
Will appreciate anyone's input on this matter, we can post this in the FAQ section if inputs are enough.
