Standalone ECM
92RedMX3
Standalone ECM
Post by 92RedMX3 »
Ok, what I am wondering is are the ECM's street legal?
David Coleman
Re: Standalone ECM
Post by David Coleman »
Define street legal. Your emissions will be better than stock with proper tuning.
David Coleman
92RedMX3
Re: Standalone ECM
Post by 92RedMX3 »
That was the main thing. Will it allow the Check engine light to come on?
maldo
Re: Standalone ECM
Post by maldo »
Depends on how you have it set. If you run in parallel you shouldn't have any problems, but then again, you won't know till you try. I know there is away around the check engine light by faking voltage. Running a standalone won't let you pass in Cali (from what I have been told) as you will fail the visual inspection.<P>You need to decide on what you will need from your system. The Link is very basic. The Haltech is very good although some will have different opinions on it. Personally, I am looking at a TEC-III as it is just that much beyond anything else on the market. With Shiv's kit, you basically have a direct bolt-in setup with preloaded base maps. Plus you don't have to worry about fabricating a crank trigger wheel. The E11 and TEC-III are nearly identical. Not sure if the E11 has its own coils or if you have to purchase an ignition system on it own. E6K is about $1000 if you know where to look (plus accesories), E11 starts at $1500. The TEC-III is $2750 thru Vishnu but includes everything (including 550cc injectors).<P>Some good reading:<BR><A HREF="http://www.miataforum.com/ubb/ultimateb ... 7;t=000030" TARGET=_blank>TEC II vs Link</A><A HREF="http://www.miataforum.com/ubb/ultimateb ... 7;t=000055" TARGET=_blank>More TEC vs Link</A><P>Do a search on<A HREF="http://www.miataforum.com" TARGET=_blank>MiataForum</A>in the power pages for E6K to find some more info. There are a few guys using it.
maldo
Re: Standalone ECM
Post by maldo »
Here is a little more info, not sure if it applies in Texas.<P><A HREF="http://www.miataforum.com/ubb/ultimateb ... 1;t=015615" TARGET=_blank>emissions testing</A>
92RedMX3
Re: Standalone ECM
Post by 92RedMX3 »
Cool, thank man!
Return to “Forced Induction”
