supra turbo ?
supra turbo ?
i had a question im hoping somone can answer i dont know much about turbos but i was wondering if a tci turbo or turbo off a supra would work in my 92 mx-3 gs? it would help alot an save me alot if i was to know thank you
92GS.KLze 2.5 ,CT26 TURBO,40K MILES,Ram air intake,2.5 cat back,coming.pullys,cams,Pistons,
valves & springs,venom injectors.
Re: supra turbo ?
the supra turbo would be too big for the gs. you would have way too much lag.
"MR." Ashley Fowler
'02 Yamaha Warrior (1700cc)
'94 MX-3 RS-t (BPT)~ sold
cardomain pics
"MR." Ashley Fowler
cardomain pics
Re: supra turbo ?
Buy the book Maxumum Boost by Corky Bell. <BR> <A HREF="http://www.amazon.com" TARGET=_blank>www.amazon.com</A> <A HREF="http://www.barnesandnoble.com" TARGET=_blank>www.barnesandnoble.com</A>
David Coleman
Re: supra turbo ?
i was wondering about the lag i was thinking if i could take a smaller turbo an have that as the first turbo then have that blow throught the bigger turbo making the lag on the bigger turbo smaller or just kick in faster....basicly making a boost for the turbo
Re: supra turbo ?
that would be a sequential turbo setup. it could work, but since you have a v-6 and not an i-6, you would have to have both turbos after your headers come together. with the room in the v6, it would be next to impossible to fit all that in there. <P>but where there's no budget, there's a way.
"MR." Ashley Fowler
cardomain pics
"MR." Ashley Fowler
cardomain pics
Re: supra turbo ?
i was thinking of having then ran from after the headers before the cat and having the turbos still kinda under the car an just pipe it to the intake<BR> well if it will work
Re: supra turbo ?
So it'd be possible in a RS but thats big bucks$$$
No Cop No Stop I Dont Care<P>Daniel Jones<BR>94' Mx-3 RS<BR>Blaze Red<BR>1.6L DOHC
Re: supra turbo ?
well thanks all .... <BR> well i think ill do it going <BR> going from almost the smallest turbo i can find to like a 17-23lbs boost and one day slap in the kl-ze with the turbos..
Re: supra turbo ?
that's a lot of work. good luck. i personally don't think there's a benifit to doing it. one turbo with the correct turbine and compressor will do the job fairly well. you have to remember that the motor you want to put it on might not be able to take the amount of boost you would be giving it. be it too high of a CR or the internals aren't strong enough. there's a lot of research needed to get the right turbo set-up along with the tuning that needs to go along with it. also, turbo manifold(s) will have to be custom made. for the money it's going to cost, i'd just stick to one turbo....the right turbo.
"MR." Ashley Fowler
cardomain pics
"MR." Ashley Fowler
cardomain pics
Re: supra turbo ?
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by cre8v mx3:<BR><STRONG>the supra turbo would be too big for the gs. you would have way too much lag.</STRONG><HR></BLOCKQUOTE><P>What year Supra. If it's the 87-92 (I believe) it's runnin the CT-26 turbo. That turbo is smaller than the T3, which is a good choice for the V6 engine. I don't know what turbo the newer supras have but I would think the CT-26 would be too small.
~Ryan~
1994 MX-3 GS Teal
1987 Toyota Pickup
SR5 Xtracab Turbo
1994 MX-3 GS Teal
1987 Toyota Pickup
SR5 Xtracab Turbo
Re: supra turbo ?
well my whole perpose that im trying to achive is minamising the lagg ...i know thatthe bigger the turbo the more lag it has so im trying to basicly make a boost for the bigger turbo im wanting around like 24 to 26 lbs of boost but to kick in around 2k my friend have a nice turbo but didnt kick in to around 4-6k rpms...
Re: supra turbo ?
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by billy:<BR><STRONG>well my whole perpose that im trying to achive is minamising the lagg ...i know thatthe bigger the turbo the more lag it has so im trying to basicly make a boost for the bigger turbo im wanting around like 24 to 26 lbs of boost but to kick in around 2k my friend have a nice turbo but didnt kick in to around 4-6k rpms...</STRONG><HR></BLOCKQUOTE><P>Go to your local junkyard and look for a t-bird coupe. They have the T3 turbo in them. They should start giving boost around 1.5K and should be fully spooled at 2.5K. The CT26 would be ok, but the T3 will be a better choice. Besided, yur engine can't handle the boost levels yur lookin for. Maybe 10PSI with GOOD tuning. The CT26 will give you little lag, but won't do the job as well as a T3. Like Dave said, go pick up Maximum boost by Corkey Bell. It will help you understand turbo's. Also there is a great guide in the latest issue of Sport Compact Car (july 2002) that will help you select a turbocharger.
~Ryan~
1994 MX-3 GS Teal
1987 Toyota Pickup
SR5 Xtracab Turbo
1994 MX-3 GS Teal
1987 Toyota Pickup
SR5 Xtracab Turbo
Re: supra turbo ?
really what yr t-bird cause that sounds good ...what am i looking for to find the t3 turbo ? if anyone could help
Re: supra turbo ?
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by billy:<BR><STRONG>really what yr t-bird cause that sounds good ...what am i looking for to find the t3 turbo ? if anyone could help</STRONG><HR></BLOCKQUOTE><P>What do you mean "what am I looking for to find the t3 turbo ?" ? Just go and find a t-bird I believe early 90's. You can also get a turbo off a gen 1 eclipse that will work well also.
~Ryan~
1994 MX-3 GS Teal
1987 Toyota Pickup
SR5 Xtracab Turbo
1994 MX-3 GS Teal
1987 Toyota Pickup
SR5 Xtracab Turbo
