turbocharging
theking6006
turbocharging
can u turbo charge a 2.5l klze and if so what turbocharger should u use. list all possible please
Re: turbocharging
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by theking6006:<BR><STRONG>can u turbo charge a 2.5l klze and if so what turbocharger should u use. list all possible please</STRONG><HR></BLOCKQUOTE><P>Yes you can, although you can only run about 7PSI max on it on stock internals.
~Ryan~
1994 MX-3 GS Teal
1987 Toyota Pickup
SR5 Xtracab Turbo
1994 MX-3 GS Teal
1987 Toyota Pickup
SR5 Xtracab Turbo
- monty73741
Re: turbocharging
7psi..........i thought that jeff abrams is runnning 10psi in his SC..........<BR>jason
Jason Danaher
Please Help Support MX-3.com
- David Witherow
Re: turbocharging
jeff is but he is also running it on a kl-03
theking6006
Re: turbocharging
what kind of turbo would i need. How long would it take to install it. How much would it cost.
- mitmaks
Re: turbocharging
so which one is better kl-o3 or kl-ze isnt kl-03 is from probes and mx-6's?
Re: turbocharging
KL-ZE is better by itself. It has more horspower. If you want forced induction, KL-03 is better.
Re: turbocharging
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Q187:<BR><STRONG>KL-ZE is better by itself. It has more horspower. If you want forced induction, KL-03 is better.</STRONG><HR></BLOCKQUOTE><P>Not true. Yes the KL_03 can hold more boost, but the KL_ZE will give you more power on max boost than the KL_03 will give with max boost. But the only way to make the KL_03 produce more power is to upgrade the internals, but if yur gunna do that, why not just upgrade the ZE internals?
~Ryan~
1994 MX-3 GS Teal
1987 Toyota Pickup
SR5 Xtracab Turbo
1994 MX-3 GS Teal
1987 Toyota Pickup
SR5 Xtracab Turbo
