Need advice...b6t turbo manifold on my dohc four
- cjthor
Hey all,<BR> I am thinking about swapping exhaust manifolds on my stock mx engine for now with the b6t turbo and manifold. How many psi can the stock engine take? I know I have to change injectors and bump the timing back.I still dont have the afc wired correctly but that wont be an issue soon. Any thoughts or suggestions?
Jarid Perry
71 Chevy C20 (tow rig!!)
2008 MINI Cooper Clubman S
- Shady469
Re: Need advice...b6t turbo manifold on my dohc four
i wanna do the same thing to my SOHC. dave said our blocks could hold 10 psi (but i think after long that would start to break stuff)but i'm gonna only run mine at like 7 . i think it would be alot cheaper to do than a swap but the 1/4 times won't be as impressive, but hey im sure it'll be quick enough. also, i thought our cars had a thing where u couldn't adjust the timing? how does one do it if we can?<BR>this guy did the swap on his DOHC: <A HREF="http://www.geocities.com/bat_elof/mx.html" TARGET=_blank>http://www.geocities.com/bat_elof/mx.html</A><p>[ February 16, 2002: Message edited by: Shady469 ]
B6T powered MX-3 - sold
Stage 3ish 03 WRX - sold
03 S2000 - current/ for sale
if you want to do the swap this way make sure you go stand alone not piggy backs you will be able to do more on the stock eternals. An mx-5 owned by Ric Stephens ran 10.80 at 126 mph at 25lbs of boost on a 1.8 n/a motor stock eternals but a stand alone system the copmression ratio will be able to help you. go for it
- cjthor
Hey there tex,<BR> I am actually only doing this as a temporary swap. I am not going to keep the stock block. I do have a b6t that I am going to use. Did you put your stand alone in by yourself? I actually need some pin locations on the ecu. Can you tell me where the tac input is and also where the +maf signal is? THanks!!!! <BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by texmx3:<BR><STRONG>if you want to do the swap this way make sure you go stand alone not piggy backs you will be able to do more on the stock eternals. An mx-5 owned by Ric Stephens ran 10.80 at 126 mph at 25lbs of boost on a 1.8 n/a motor stock eternals but a stand alone system the copmression ratio will be able to help you. go for it</STRONG><HR></BLOCKQUOTE>
Jarid Perry
