People with the BPT swap come and help me!!
The_Great_Tonge
Post by The_Great_Tonge »
Ok i have set my mind on the BPT with 180hp. Ok i know it cost $990. I need you that have done the swap to list what else i will need(Example: Fuel pump) and there prices. Help a brotha out!
The_Great_Tonge
Re: People with the BPT swap come and help me!!
Anyone?
Marlon
Post by Marlon »
i'd like this info 2<BR>and how much the swap cost when done and how much hp you got<BR>thanks<p>[ January 21, 2002: Message edited by: Marlon ]
1993 MX-3 GS V6 - Stock
2004 MazdaSpeed MX-5
2004 RX-8 - Project
Manach
Post by Manach »
Didn't David post something about it?<P>I'll try to find it back..<P>From a post David made :<BR>Well, here are the things that you will need. <BR>1. Mazda BPT GTX/GTR Engine (GTR Preferable) <BR>1a. Good ball bearing turbo (I am using T05) <BR>2. Gearbox from 1.8L DOHC Protege (Prepared to blow 1 or 2 of this) <BR>3. Custom C.V joint and drive shaft (Need to be strong) <BR>4. Custom intercooler (As large as possible) <BR>5. Custom stainless extractor with 3" mendral bend exhaust system <BR>6. Wolf 3D ECU (It has wiring harness for this engine) <BR>7. Electronic boost controller (HKS, Apexi, Greedy) <BR>8. Boost, A/F, Water Temp. gauges <BR>9. Heavy duty clutch <BR>10. Brake enhancement (At least pads and crossed rotor for F&R) <BR>11. Custom radiator (I cannot find anything 2nd hand fits) <BR>12. Custom Oil and Air seperator <BR>13. Custom Water overflow tank <BR>14. Good dyno for tuning <BR>15. A lot of spare time and money!!!<P>With that.. I think you can look around how much those parts cost. Some might be needed when you swap, some might be add later.. So I think..<P>I'll do some research on those too in a near future.. :)<p>[ January 22, 2002: Message edited by: Manach ]
Manach
Ex Mx'er with a Mx-3 1993..
Still in the Mazda Familly with :
-Mazda Rx-7 1987 GXL (Not running, one housing does not compress)
-Mazda Protege MazdaSpeed 2003.5 Titanium!
Still got 3 Engines!
- B6-ZE : Turbo Festiva project (Waiting donor car)
- BP-DE : Trader for a B6-ZE 1994 for parts upgrade in the Festiva project
- K8 : For sell. Pm me for info!
Once you go turbo, you can never go back!
ProtegeSTS
Post by ProtegeSTS »
remember to buy an EGT gauge as well...very important in tuning, and a lot more accurate and faster reacting than an A/F ratio gauge.<P>Also, custom piping is usually a bit more expensive than 100 bucks.
-93 MR2
#129 E-stock
OsoSlo z28
Post by OsoSlo z28 »
does the egt detect the intense momentary heat from detonation or does it detect the gradual increase in temp from the car running leaner? just wondering how fast it reads temp.
"MR." Ashley Fowler
'02 Yamaha Warrior (1700cc)
'94 MX-3 RS-t (BPT)~ sold
cardomain pics
Turboge
Post by Turboge »
The EGT when mounted in the proper place will react instantaneously to changing cylinder temps. I have mine mounted in cylinders 3/4 facing mainly into 3. This won't show you "detonation" but alert you to rising cylinder temps that can create detonation if not tuned correctly. This combined with a Wideband o2 and a dyno prove to be a killer combo for tuning.
Braden
"The Original Turboge"
http://barelylegaltransplants.com
OsoSlo z28
what temps should i use as a guideline? what's normal? what was your reason for mounting it where you did?
"MR." Ashley Fowler
cardomain pics
Return to “Forced Induction”
