I got the wheel on, and got to the tricky part. The horn. Basically I need instruction on the wiring of the horn, and how to install it, from someone who has a MOMO on their car...
Mines confusing aswell. I had Cruise before and removed the circle thing that had the cruise connection on it. And then tried connecting the one wire that remained as my horn and it didnt work. My guess is that the wire comming off the cruise control also has something to do with the horn. Someone that has a Momo or aftermarket wheel with a working horn (that means you dont count Darren :p ) Please explain this to me!
Mods:
- ZE, Mike seli 214 intake cams, Ported n polished heads, Interprep valve springs, DE retainers, rebuilt bottom end, toga main and rod bearings, toga hv oil pump, CZT 67mm tb, mbx udp, ported intake mani, SS headers, 2.5inch full exhaust, racingbeat muffler, highflow cat, megasquirt v2.
new toy, 86 TII rx7, JDM S5 motor/turbo, + alot of other goodies
ive heard it is illegal to have an aftermarket steering wheel cuz it disengages the air bag is that true its the only reason i havent be shoppin for one does anyone know the regs for them?
Mods:
I am solving the no horn dilema as we speak.
I am ripping out the OEM horn alltogether. Not a great horn anyway...(meep meep)
I'm going to install a 2 tone (hi/lo) snail horn. It's actually 2 seperate horns 1 high the other low. They are red and chrome...very nice, so I'm going to mount 1 on each side of the engine bay in a visible local.
It's a single wire from the wheel to a relay to the 2 horns. it blasts like 130db.
MOVE OVER GRANDMA!!!!!!
<small>[ October 16, 2003, 07:50 PM: Message edited by: Darren Hyderman ]</small>
Sweet man! You gota show me that when its all hooked up. Then we can go around scarin kids haha.
Mods:
Oh and ive made some progress on the horn. Ive figured out that there are 3 rings on the steering column that the momo hub slides onto. These three rings are somehow related to cruise on and off and the horn. And are divided by little plastic rings. If i take a wire and connect the top ring to the middle ring i get the horn. (at this point i'm sure all my neihbors were getting ticked off) So i just slapped the wheel back on for now.
So now i know i need to make one of those 2 rings come in contact with the momo hub and we should have a working horn! I'll try this out soon and get back to you guys.
Mods:
