door mod
Shoalinfist
door mod
Post by Shoalinfist »
I'm redoing my doors and need so help. How do you put on the new fabric w/o getting wrinkles all in it (, cause I keep getting wrinkles). And what should you use to get it to stick? I tried an all purpose adhesive but it doesn't work to well. Any tips.
Custommx3
Site Administrator
Re: door mod
Post by Custommx3 »
do what I did.. I bought new door panels and said screw it. Mine looke dgreat, till the heat got it. The glue came loose and wrinkles/air bubbles galore.
LiquidMazda
Re: door mod
Post by LiquidMazda »
Hey Barry, Where did you buy new door panels???
Liquid Mazda
Custommx3
Site Administrator
Re: door mod
Post by Custommx3 »
Was either ..<BR><A HREF="http://www.mazda-dism.com" TARGET=_blank>Mazda Dismantlers</A><BR>or<P><A HREF="http://www.mazdarecycling.com" TARGET=_blank>mazda recycling</A><p>[ April 04, 2002: Message edited by: Custommx3 ]
Shoalinfist
Re: door mod
My door panels are fine but I want blue or white in it. but if it screws up that bad I might just leavfe it alone all together and just have my seats done.
RaspMetalicMX3SE
Re: door mod
Post by RaspMetalicMX3SE »
for the fabric you need to buy some that is stretchable the wrinkles will come out and smoothen if its stretchable. I used that 3M super 33spray, it works alright, the only thing i have a problem with is the edges i have to get something that goes in the crevases but for the most part its looks good
Max
Re: door mod
Post by Max »
I tried two different kinds of vynil fabric and it didn't work...Contact cement wouldn't hold... it looked ok but not perfect... I wouldn't do it again... beside it's whats under the hood thats counts...<BR>i aslo had to get new door panels at a junkyard...<P>Good Luck ...
VizualXTC
Re: door mod
Post by VizualXTC »
From what I'm reading it's a hard procedure. I'd buy some spare panels to f--- around with and if you mess up, oh well. Especially from a junkyard they couldn't be that expensive. As for adheasive. What is wrong with old fashioned Elmers Glue-All? Spread a thin coat and thst should do the job. (I dunno what kinda material the panel is, but if it's solid, and not a porous fabric, the glue-all should work fine) Or do what I am contimplating. I may put painted fiberglass inserts in. Give it a shiny look. Just my thoughts. Good luck my man.
~Ryan~
1994 MX-3 GS Teal
1987 Toyota Pickup
SR5 Xtracab Turbo
Sonicxtacy02
Re: door mod
Post by Sonicxtacy02 »
Im having the same probs barry was as far as the bubbles.. so i bought new door panels from Mason and i'm just going back to the original color. Shops were trying to charge me 250 + cost of vinyl and frankily, thats a waste of money. As for the adhesive the 3M product is good. The only problem with elmers is its thick and you may be able to see through the vinyl. It would take alot more work if you didnt use a spray adhesive.
Shaun Newman
Return to “Appearance”
