Turn signal problem
airjordon_09
Turn signal problem
Post by airjordon_09 »
now im having some problems, my front ones work, but my rears dont, they go twice as fast in the front, but dont go in the back, does anyone have any ideas on why that is, havnt had the time to **** around with it yet, but has anyone else had the same problem with theirs??? thanks
JºrDôñ
Mx sold, gonna miss ya babe
E-MAIL
gti_driven@hotmail.com
papa roached
Re: Turn signal problem
Post by papa roached »
check the fluid levels (replace the bulbs)
marshmallow15
Post by marshmallow15 »
that is very simple to fix.. you say your rear bulbs wont turn on? then obviously they're busted (one of the inserts out of two that light up) and if thats the case (which im 90% positive), then it'll make your front turn signals faster. vice versa goes with if front bulbs are messed up, the rears will go faster.<p>long story short, if you replace the rear turnsignal bulbs, everything will be ok.
- team slideways
