anyone tried these short shifters on ebay, any good?
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=33736&item=7930421167&rd=1
short shifter on ebay
- mitmaks
Re: short shifter on ebay
B&M short shifter style, I have one in mine, no problems yet.
was it a drop & go type thing w/your b&m?
i talked to a mechanic that wanted to charge me 70 bucks to "adjust linkage" or some crap like that (because it's not guarenteed to fit er something) so i figure i'll handle it myself...
- papa roached
there is not adjustment, they fit, i got a OBX from ebay, fit perfect and that should drop right in after pull the spring thing, gro harlem has a good write up on his site about changing it, super easy
