2nd coolant sensor install how to
TsiMiata
Post by TsiMiata »
I made up a web page showing how to install the 2nd coolant sensor when doing a ZE swap. There are some mpics I didn't get which would have made things clearer but it's better than nothing. If this could be somehow converted and placed into the FAQ section that would be great.
http://www.realperformance.org/2ndsensor.htm
<small>[ July 26, 2004, 06:30 PM: Message edited by: TsiMiata ]</small>
91 Eagle Talon Tsi AWD *RIP*
DJester187
Re: 2nd coolant sensor install how to
Post by DJester187 »
Thanks Tsi, :2thumbsup: :werd:
Electric Black '93 MX-3 GSR, Curved neck KLZE, KL36 ecu, Outlaw Engineering Thermal Spacers, Custom CAI, Carbon Fiber Invader Style hood, 2.25" straight pipe exhaust, custom muffler, lowered 1.8", and a set of 17" Exel DL-46's. With more to come once I get some $$$....
Damious
Post by Damious »
is there a way to avoid having to do this? like get a specific year Ze or something? just curious but awesome write up.
-Damian
***if u know of/have a mx-3 GS with a blown engine and live around me... let me know ;) ***
papa roached
Post by papa roached »
some have both sensors, some done, i got lucky, mine does
IanL
Post by IanL »
In between drilling the neck, and putting the tap in, the pic shows the neck acquired a lovely shiny flat face. What did you use to do that?
Extra thick soundproofing in the boot (trunk) to quieten my stainless steel exhaust system :)
TsiMiata
Post by TsiMiata »
The way the sensor seals from the factory is with a spot face. I spot faced the waterneck but didnt do a good enough job and it leaked. I found sealing it with the o-ring was the most idiot proof method.
Heres the kind of tool I used-
http://www.mscdirect.com/PDF.process?pdf=213&Section_Id=539&Keyword=Y
