Clutch Questions
Clutch Questions
Can the Clutch and flywheel from a 2.5 ltr probe/mx6 be used on the mx3? aftermarket wise...
Re: Clutch Questions
Yes they are interchangeable, I believe the 2.5L Clutch and Flywheel are about 10mm larger in diameter, but they are interchangeable.
<small>[ April 15, 2004, 11:31 AM: Message edited by: Talon_66 ]</small>
93 GS, KLZE, KL31 ECU, Centerforce Stg 3 Clutch, 2.25" Exhaust w/Flowmaster muffler, OBX Headers, Pheno Spacers, Front & rear X-drilled/slotted Rotors, KVR pads, SS brake & clutch lines, Ractive Filter, H&R Springs, Tokico Blue Struts, 8mm Accel Wires, MSD 6A w/ Blaster 2 Coil, HVAC Indiglo Panel. *Sold*
06 Eclipse GT *Sold*
08 Evo X GSR *Current*
Just the clutch is bigger, the flywheel is the same diameter. You can use a 1.8 flywheel with a 2.5 clutch or a 1.8 clutch on a 2.5 flywheel(all though I don't see why you would). It all swaps around.
91 Eagle Talon Tsi AWD *RIP*
If u go to the Auto parts store and ask for the Ford Probe clutch, u will more then likely pay a lot less.
- papa roached
not to mention a "free" upgrade
well for the guy who said that it is cheaper for the probe clutch.. heh thats what my plan is.... the clutch/flywheel is about half the cost of the aftermarket mx-3 ones.. Cool that works out great.. saves me about 250 bones
thanks fellas
No problem. Good luck with the swap!
