Rotors Drilled Slotted
Low3-XM
Post by Low3-XM »
I'm looking on ebay... is there a honda rotor or a diff kind of rotor i can use i'm looking for 4 drilled slotted for a 93 gs.. if i can't use any other wut should i be typeing in and if i can use diff ones what rotors can i use
C-MX-DA3
Re: Rotors Drilled Slotted
Post by C-MX-DA3 »
i know there is many types of rotors that would fit the gs.( powerstop, brembo, powerslot and ractive) are some of the few that has application for mx3.
Low3-XM
Post by Low3-XM »
i know there are diff brands but can i put civic rotors on my car.. or some o ther rotors but still drilled slotted
mitmaks
Post by mitmaks »
go to your local parts store and ask them for mx3 rotor and civic and compare their size, that will be most easiest.
Low3-XM
Post by Low3-XM »
well i was wondering about the 4 lug becuase civic rims will fit our cars so will rotors ?
Steeb
Post by Steeb »
http://erdtforum.teamzx2.com/viewtopic.php?t=7832
http://www.clubprotege.com/forum/showthread.php?t=2157
save your trouble... :shrug: and yes, any 4x100 lug rim will fit with the correct offset
FlyingMXer
Post by FlyingMXer »
Are the rotors on the GS the same as the ones on the front of the RS?
Later, D
92 4-banger (totaled unfortunately. Current ride is 2001 Mustang GT)
Low3-XM
Post by Low3-XM »
so if i order protege dilled slotted rotors... they will work becuase i wanna buy'em off ebay.. and get something like papa roached. and all i can find is rotors for any other car exept the mx-3. so i can order protege rotors an they will fit ? specific year i have to go by ?
