KLZE header options?
Gro Harlem
Post by Gro Harlem »
I did a search and didn't find any definite answer to this question.<p>Everyone says to use the K8 exhaust manifolds if you swap in a KLZE. <p>Are there any headers available for the K8? I would imagine they would work with the KLZE if there are any available<p>Also, I read that you can use the Probe/MX6 headers, but have to relocate the cat a few inches back. Do you have to modify the headers at all? or just the existing piping / downpipes?<p>
Thanks for your help
DONATE TO MX-3.COM
zevirii
Re: KLZE header options?
Post by zevirii »
You can use the Probe/MX-6 headers called "HOTSHOT Headers" on the K8. You will have to relocate the CAT about 2 inchs or so back. You will also have to have a bong wielded on at the muffler shop for the rear O2 sensor. The EGR system will not exactly line up, but there is a EGR port in the header for you to use. I don't know what you will have to do on this cause I didn't use the EGR system on my engine... All of the above was very easy. The EGR will just need alittle bending in the pipe I guess, nothing a muffler shop can't handle I am sure...
Gro Harlem
IF you use the KLZE ecu you don't need to use the EGR stuff right? I thought that EGR crap was K8 specific? Or am I wrong
DONATE TO MX-3.COM
JasonH
Post by JasonH »
It's a "bung". A "bong" is for something else. Heh.
zevirii
Post by zevirii »
hehehe... The EGR is for U.S. Cars.. The KLZE doesn't have EGR.. In my case I cut the EGR tube off the header and had it welded over..
Gro Harlem
Cool. I'll probably get the pacesetter headers. A buddy of mine with a 626 put them on his KLZE and he said the differernce is like night and day.
DONATE TO MX-3.COM
mazdasly75
Post by mazdasly75 »
A longer primaries section headers would be a good choice for ZE, since it deliver most of it's power at top end. <p>I would go with the pacesetter, it has longer primaries than hotshot.<p> :shrug:
1996 MX3, KL, stock internal, T3T4, 10psi, tial wastegate and blow off, 450cc injectors, 255lph, 3" mandrel bend exaust, 67mmTB, megasquirt II, launch control/flat shift, boost controler, 4bars MAP 16x16 built in, 300whp
M0RDECHA1 MANDELL
Post by M0RDECHA1 MANDELL »
I am just wondering why pacesetter headers are better then the hotshots. I have heard nothing but good things about hotshots and badthings about
pacesetter products. :shrug: <p>can someone clear this up?
"They're 2 types of people in this world, people that work for money and people that make money work for them."
Zoso124
Post by Zoso124 »
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by BUG$Y:
pacesetter products. :eek:
Mike Evans
Gone:
lazzyie
Post by lazzyie »
Pacesetters make more power but are made less precisely....
93 Mx-3 GS klze swapped(sold)
96 Integra LS DD
91 Crx Si drag car
2.0L sleeved gsr block, forged internals, skunk2 valvetrain, HP racing intake manifold, Holset H1 turbo, 1000cc injectors, short geared lsd transmission, 3" turboback exhaust. 20 psi :)
Buff1110
Post by Buff1110 »
im gonna share my experience with ps headers over the past few days. i have the klze in my 92 gs. first off the qualitey isnt to great but for 200bux u get what u pay for. now fitment is the main concernm. they do not fir correctly at all. save urself teh money and dont get them. my set is ruined now . basically the front header flanges hit the oilpan and the rear header hits the frame. the y pipe hits the shifter stabalizer. after cutting the flanges to make them fit i could not get a good seal and the y pipe is still up against the shifter stabalizer and really close to my shift linkage. im putting on the stock ones again. i dunno how hotshot fits but pacesetter just didnt work out the way i had planned
Dan
92 Mx-3 Gs, KLZE Powered!! - SOLD!!!!
02 Tacoma TRD - Daily
93 Honda del Sol - New Project
Smokin mx-3
Post by Smokin mx-3 »
k u cant beat the price 200 for pacesetter but the cars that i heard them on sound like trap along with the gains takes away from low end and give you high
i have had bro speed and the dyno charts that i have seen they give you a even power band and hot shot are right up there with bro speed but they are expensive but you get what you pay for
