Rotor and pad change
I am panning to change all the pads and the rear rotors. This would be my first DIY. but the mannual does not mension how the change the rotors, and only a photo on pads. Any tips on the job? thank.
Re: Rotor and pad change
Front rotors are a piece of cake. Remove the caliper by removing the two bolts. Just knock off the rotor. The rear a little trickier. Take off the caliper with the two bolts that are a little more further in. You'll see how its different that the front because the front half of the caliper has one bolt not two and there are two more bolts on the caliper support (remove those). There will be two screws holding the rotors onto the hub. Remove those first and knock off the rotor. If the two screws don't come off, drill through them! I've been told you don't need them. Install is reverse of install.
