Manifold Absolute Pressure/Barometric Pressure Circuit
DeanoGS
Post by DeanoGS »
This is the code readout i get on my 1.8l V6<P>P0105 Manifold Absolute Pressure/Barometric Pressure Circuit Malfunction <P>Apparently this doesnt exist on these engines? Can someone tell me what this error is and what sensor it leads to?<P>dean.zarrillo@mts.net
David Coleman
Re: Manifold Absolute Pressure/Barometric Pressure Circuit
Post by David Coleman »
You'll note in the F2 chapter of the shop manual that it says to replace the ECU if you get this code...
David Coleman
DeanoGS
Post by DeanoGS »
CRAP!! Where does it say that? and can you please explain a little more as to why this is happening.<BR>Thank you.
DeanoGS
Post by DeanoGS »
The shop manual says replace ECU when u get code 14( bar. pressure .... )<BR>i get code p0105, which isnt 14, but is : Manifold absolute pressure/ barometric pressure ciruit malfuntion.<P>Im totally lost!
DeanoGS
Post by DeanoGS »
ANY one?? Help?
