The ne guy has questions
ApocalipticSol
Post by ApocalipticSol »
ok i been looking and looking... i allready have plans for the mx but i saw something i realy like and i belive its stock... the dash with the circle vents.... what mx-3 had it what years and models and will it fit in the 93 whatever i have with the square dash....<P>also i see there are no projector headlights for mx3 either...how about carbon fiber altezzas..... i guess not since i haven even seen normal altezzas yet.....<P>what mods can be done to the taillights i just dont like the way the set in.... <P>THANKS FOR ANY HELP<p>[This message has been edited by ApocalipticSol (edited July 17, 2001).]
Guest
Re: The ne guy has questions
Post by Guest »
The curvey dash was introduced in the 94-up mx's, They came with and without airbags.<BR>Yes it will fit in the 93 and down models but its alot of money and work. You would need to buy the new dash, the a'c ducts, the intrusion beam for the dash, the glove box, and the center dash assembly holding the ac controls and the radio., you will need all the way down to the part that goes around the e-brake, also where the lower part of the Steering column is different. the shaft that the steering wheel is mounted to is two pieces, You will need the upper half of the shaft for the steering column to bolt up to the new dash intrusion beam, and the Combination swith with the turn and wipers will not fit the 93's model and the 93's will not fit the 94's style steering column, also the horn setup is differnt for the old interior and the new interior, <P>To put it simply, Id find a newer mazda you like and buy it or stick with what ya have, <P>Hope this helps ya, Chirs <P>Have fun either way you like, Chris
Guest
Post by Guest »
Oh Yea and the Air conditioning controls are different! they are electric motorized or full logic instead of the slide bar type.<P>Chris
