distributor nightmare
K-man
I believe I am experiencing the distributor nightmare with my GS. I have replaced the whole unit once already and tyhe symptoms have returned a year later. No here's the funny thing...if I drive the car below 3000 rpm the car will not stall. If I drive above 3000 rpm (were all the fun is)<BR>the car will stall. Is this typical? Is it just the ignitor module or does the whole distributor need replacing....again?? I found some info on Jeff Abram's site regarding replacing the module. But does this really solve the problem or will the symptoms return down the road???
Re: distributor nightmare
Maybe you replaced your old disty with the same old model, not the revised one.<BR>It is possible and then you may have the igniter failing, cheaper if your can buy it alone.<BR>I think the old was labeled KL01 and the new one KLY1... [img]shrug.gif"%20border="0[/img]
