Oxygen sensor not needed?
My MX-3 GS has been running crappy lately. It seems like it trips over itself on take off and has very little power. I hooked it up to my buddy's scanner and it displayed codes 16 and 17. Code 16 is a bad left O2 sensor so I got another one off a junked Mx-3 and started to swap them. while doing this I had an idea. I took my car for a drive with the old sensor still in but unplugged. It ran great. I don't know how this could be. I assumed the car wouldn't even idle, but it runs great, smooth take offs and lots of power. <P>If someone with a good running car could disconnect their O2 sensor and let me know how it ran I would really appreciate it. Someone more knowing please write back.
Re: Oxygen sensor not needed?
my cars got some prob i wounder if thatll fix mine .. ill try it this afternoon an get back to u .. did u unplug from or back ..or both ?
92GS.KLze 2.5 ,CT26 TURBO,40K MILES,Ram air intake,2.5 cat back,coming.pullys,cams,Pistons,
valves & springs,venom injectors.
- Buff1110
watch out though because bad o2 sensors = bad gas mileage<BR>no o2 =???<BR>Dan
Dan
92 Mx-3 Gs, KLZE Powered!! - SOLD!!!!
02 Tacoma TRD - Daily
93 Honda del Sol - New Project
Mike 94PGT
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by chance:<BR>[QB]My MX-3 GS has been running crappy lately. It seems like it trips over itself on take off and has very little power. I hooked it up to my buddy's scanner and it displayed codes 16 and 17. Code 16 is a bad left O2 sensor[/b]<HR></BLOCKQUOTE><P>Code 16 is an EGR fault, not an O2 sensor. O2 sensor codes on OBD-I cars are 15, 17, 23 and 24.<P>You sure you read 16?
Mike<BR>94 PGT <A HREF="http://home.golden.net/~trinity" TARGET=_blank>Codes, Maint, MAF, PCMs etc...</A><BR>Supermoderator, mx6.com
i pulled front o2 sencer ran little better then removed sec an ran like crap.. be nice if we dont need them
pelado
O2 sensors aren't all that expensive. Go to Nopi or <A HREF="http://www.oxygensensors.com." TARGET=_blank>www.oxygensensors.com.</A>
I'm sorry, it read 16 and 17. 17 is the o2 sensor not 16. I only pulled the front one.<BR>Better gas mileage or not it still runs considerably better. Tomorrow I'll put the other one I have in and see what that does. I just thought the whole thing was kind of interesting.
