Synthetic or mineral oil? Which is best to use?
I have heard both. Which is best to use and why?
Angel
Re: Synthetic or mineral oil? Which is best to use?
I cant say why, but i've always heard that synthetic is best. But that is just hear/say.<BR>wish i knew the answer. im sure the allmighty Barry Clark knows.
Build A Man A Fire, He Will Be Warm For A Night. Set A Man On Fire, He Will Be Warm For The Rest Of His Life.
<img src="http://www.bareend.com/mazdaspeed.gif" alt=" - " />
synthetic is a better oil IF you use it right from when the car rolled off the line.<P>I changed over to synthetic oil at about 130,000km and my engine burned it off in about 800km's! Put Castrol GTX 10w-30 back in and my engine no long burned oil. That's just my two cents...
<img src="http://members.rogers.com/zytariuk/images/mx-3.gif" alt=" - " />
1992 Mazda Mx-3 GS - Beige metallic
zytariuk's mx-3 page (updated June 12th, 2003)
Amsoil synthetic is the way to go. <A HREF="http://WWW.AMSOIL.COM" TARGET=_blank>WWW.AMSOIL.COM</A> <BR>25,000-35,000 miles before an oil change. Check it out, They warranty it.<P>Synthetic oil will outlast any conventional oil. Also synthetic oil will hardly burn any oil at all compared to regular oil. Synthetics have a higher thermal breakdown than Castrol/others, and will not burn any faster than regular oil. It's a proven fact from the oil research scientists that have been researching and testing oil for over 30 years. FYI they are called Tribologists.
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by zytariuk:<BR><STRONG>synthetic is a better oil IF you use it right from when the car rolled off the line.<P>I changed over to synthetic oil at about 130,000km and my engine burned it off in about 800km's! Put Castrol GTX 10w-30 back in and my engine no long burned oil. That's just my two cents...</STRONG><HR></BLOCKQUOTE><P><BR>I hear that sometimes it is bad to switch to synthetic. It causes oil leaks in some older cars that have been using regular previously.<P> [img]shrug.gif"%20border="0[/img]
Amsoil, Redline or Royal Purple are the best fully synthetics out there now. Mobil 1 has now been reformulated with a higher Ash content, for whatever reason.. [img]shrug.gif"%20border="0[/img]
David Coleman
What did the MX3s used to come with stock? 10w-30? (that was just a guess for the record). <P>So its probably not the best idea to switch to synthetic? or should i try one of those for high mileage engine blends?<P>Im just wondering because i want to do whats best for the car and give me the best mileage while hopefully not sacrifice performance or very little of it.<P>Im looking for your advice... what do you guys use?<P>Its the 1.8L V6.<P>Thanks for your input!
