Burning oil
Burning oil
I was wondering if there is any common mechanics that go wrong with this car. i ahve a 92 gs. I can't figure out what it is, I tried the stuff that is supposed to stop leaks that you add to the oiland it didn't work. And I really don't have the money to have the top of the engine rebuilt, so is there anything that will prevent this, just enough to last atleast a few days so I can pass the inspection, then after that if I have no other choice, I will have time to save some money to get the engine repair correctly. So again if anyone can help it will be greatly appreciated.<P>Thanx
Re: Burning oil
well is the oil on the upper or lower half of the plug, if its the top half you can just mop up the oil with a rag and replace your valve cover seals, or if its the bottom half it is probably a head gasket
93 Mx-3 GS klze swapped(sold)
96 Integra LS DD
91 Crx Si drag car
2.0L sleeved gsr block, forged internals, skunk2 valvetrain, HP racing intake manifold, Holset H1 turbo, 1000cc injectors, short geared lsd transmission, 3" turboback exhaust. 20 psi
96 Integra LS DD
91 Crx Si drag car
Re: Burning oil
Its not leaking in the engine, it is burning, can coming out the exhaust.
MI-Archangel
Re: Burning oil
AKK m\MX-3 brun oil dont tell me differnt its be cuz their engine run hoter then other cars
