A/C system....do it yourself???
Mradio
here is the problem:<BR>during the engine swap all the freon was let out... now it's like 90 degrees here and I need the A/C back. It turns out that my car 92 mx3 has 12 freon, which is very expensive.<BR>is it possible to fill it up with 134?<BR>if not, is it possible to fill up the a/c system yourself?<BR>thanks
Check out my ride and leave some feedback please!
http://www.cardomain.com/id/mradio007
Re: A/C system....do it yourself???
You can use 134a as long as the system has been completely evaced.
Mradio
r u sure on that one?<BR>my mechanic said that compressor might seize. [img]shrug.gif"%20border="0[/img]
The two refrigerents (actually i believe it is the oils) don't mix. If you mix the two together then you risk freezing the compressor. A mechanic is going to tell you whatever makes him the most money. You only need the high and low adaptors. Do not overfill the system. I believe the ratio is 80% 134a to R12.
pelado
I bought a kit from WallyWorld and did it myself, it's pretty easy. Rent a vacuum pump and the gauges or do like I did, borrow them from a friend.
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by pelado:<BR><STRONG>I bought a kit from WallyWorld and did it myself, it's pretty easy. Rent a vacuum pump and the gauges or do like I did, borrow them from a friend.
</STRONG><HR></BLOCKQUOTE><P>I agree, you should buy an upgrade kit.
~Ryan~
1994 MX-3 GS Teal
1987 Toyota Pickup
SR5 Xtracab Turbo
1994 MX-3 GS Teal
1987 Toyota Pickup
SR5 Xtracab Turbo
