+5-15hp coolant line bypass
heavenzjai
just saw this on Ebay too, explain? i think all this stuff is a rip off.
916 Blk MX3 V6
Re: +5-15hp coolant line bypass
This is a modification to the coolant lines that go to the throttle body. Instead of running hot coolant threw the throttle body you bypass it keepin it much cooler. There is a long write up on Probetalk so check it out. David has don this mod to his MX-3 so if you have any questions you should ask him. Whatever you do don't pay for this modfication.
