Amp Rack
Car Stereo/Alarm Discussions
Sonicxtacy02
Amp Rack
Post by Sonicxtacy02 »
Anyone made one? If so.. how?
Shaun Newman
loudsubz
Re: Amp Rack
Post by loudsubz »
we made one on the back of my friends seat in his mx3. Check it out @ <A HREF="http://members.sounddomain.com/polskis_mx3" TARGET=_blank>http://members.sounddomain.com/polskis_mx3</A> <P>He wants to do a whole new desing soon though.
Da_Wiggy
Re: Amp Rack
Post by Da_Wiggy »
sorry for the off topic reply but Loudsubz could you tell me where to find the specs on your friends clarion sub? I have 2 (12 inch) in my car right now with 200 watts each (clarion 400.2)and I'm not satisfied with the spl (I think it's the box). I bought them off a friend who knew nothing about them so any info would be great<BR>thanks
loudsubz
Re: Amp Rack
Post by loudsubz »
Outside dia: 12.25"<BR>Mounting hole: 11"<BR>Mounting depth: 5 3/32"<BR>Sensitivity: 89.0 dB<BR>Max peak: 500 W<BR>Continuious power: 250 W<BR>Nominal impedance: 4 ohm<BR>Re DC imp (+-10%): 3.39 ohm<BR>Le 2.72mH<BR>V.C. dia.: 2"<BR>V.C. length: 0.961"<BR>Air gap: 0.312"<BR>Piston dia.: 10.2(0.2591m)<BR>Sd: 81.7 (in)2<BR>Vas: 2.29ft3<BR>Fs: 32.6hz<BR>Qts: 0.413<BR>Qes: 0.426<BR>Qms: 13.883<BR>Mms: 143.6 grams<BR>Mmd: 136.7 grams<BR>Rms: 2.11 kg/s<BR>Bl: 15.3Tm<BR>Speaker displacement:<BR>Front mount: 103.4 in3<BR>Rear mount: 162.3 in3<BR>Xmax: (defined as 1way linear excursion)0.37"<BR>Magnet weight: 50 oz.<P>SPL 89.2dB @ 1W/m<BR>Frequency response 20Hz ~ 1.5kHz<P>Sealed/ Acoustic Suspension<BR>Enclosure airspace (unfilled) = 1.25ft3<BR>Enclosure airspace (filled) = 1.04ft3<BR>Fc = 55.81Hz<P>Vented/ Bass Reflex<BR>Enclosure airspace = 2.77ft3<BR>Fb = 30.35Hz<BR>F3 = 29.23Hz<BR>port size = 3" I.D. x 7.07" length
Da_Wiggy
Re: Amp Rack
Post by Da_Wiggy »
thanks a lot....you're the only person i've ever talked to that knows anything about them!!!!<BR>much appreciated
loudsubz
Re: Amp Rack
Post by loudsubz »
No problemo man, always glad to help out.
Return to “Car Stereo/Alarm”
