Studs
K-money
Studs
Post by K-money »
Hey every one I have a question I royalty fucked up yesterday and forgot to torque my lugg nutts after changing my axle as a result my tire came off and it sheared one of the ends on one of the studs my question is can the studs be replaced or will I have to find a new hub.
Weistal67
Re: Studs
Post by Weistal67 »
Technically, it is possible to press out the old one and press in a replacement. However I'd recommend doing the whole hub assembly if it's within your budget.
Re: Studs
Oh man that's the stupidist thng I've ever heard of. Bet no one here has ever done any thing as stupid as that. :wink: If the hub looks fine swap out the stud and you should be fine however, check the other studs as they're probably knackered as well.
DeadMaker
Re: Studs
Post by DeadMaker »
+1.
I had a broken stud and the replacement took about 5 minutes
Black Mazda Mx3 Rs 1997 B6DE
MrMazda92
Re: Studs
Post by MrMazda92 »
Given the situation, I would replace the entire hub, as well as the wheel-bearing. Check the bore of the spindle(carrier) as well, just to be safe...
If everything seems to check out, with no odd movement or vertical/horizontal play, you can buy studs for cheap on RockAuto. I have a few dozen old studs(pressed in extended studs), but it would cost about the same to buy new as it would to ship mine out.
