I had squeaking brakes on my truck for a while, I kept ignoring it figuring it just sliders that need greased.
So if your brakes squeak you might want to check them out asap.
Magnum s/s lines, strut bars, carbon fiber bezel, indiglow gauge, Sony Xplod, inverted c/f hood, SRD lower tie bar '93 GS SE '95 Cobra SVT #2722 '68 Charger R/T 440 http://www.cardomain.com/id/mitmaks
Wow I would expect to see something like that if you lived somewhere that had road salt. Not Washington
Usually it's the cheap pads that squeal. Lubricating your sliders with anti seize is a must as well. Those brakes look pretty bad, were you towing a heavily loaded trailer or some thing?
