what is this ECU used for?
burgess
Post by burgess »
hey i found a ECU that was given to me when i bought my car. it says B6DD on it can anyone tell me what it would be for?
Evo_Spec
Re: what is this ECU used for?
Post by Evo_Spec »
i think it should be B6DE, it should be for the 94-95 4cyl, but i'm not sure, it's for a 4cyl for sure
burgess
Post by burgess »
oh i ment to ask if its for a mtx or atx because im in process of doing the swap.
Ryan
Post by Ryan »
Doesn't matter, you can use an ATX ECM to power a MTX.
burgess
Post by burgess »
well i was reading the other thread about swapping atx to mtx and you say that there's some sort of problem with the ECU when swapping trannys in a b6de. what problem were you referring to here?
