not going for the factory look. I know some of you only like the mx-3 that
way, but I have a very hard time finding other mx-3s so its better for me to
go this way.
Alright so it is about time I start one of these up. To save time and work,
here is a link to the car when I got it, along with what has been done to it.
viewtopic.php?f=1&t=76387&p=573116#p573116
I finally got a job and started working on how it looks, seance it runs and I
don't have the money,tools, or room for a swap. So the first thing I did was
bought a cd player.
The last owner kind of killed the wiring harness for it, so I had to cut the
factory harness off. Then rewire it straight to the cd player. Sucks a lot I know
but after 3 hours of playing wire match up. I got that working, sadly though it
dose not save memory and kills my battery. Got to figure out how to rewire it.
Seance pretty much every speaker in the car is ruined, I started looking into new
sets. My brother gave me a set of fusions. So I went ahead and bought another set
for the back of the car.
Now I get to re-plaint everything that I did white, green haha.
Now I am currently working on the door panels. The ones I got when I bought the car
were half fiber glassed and coated with some fabric. along with the factory materials
taken off. After I got all of the old fiberglass and fabric off I learned that most
of the foam was stripped off. I went ahead and finished it off and sanded it down.
Now they are ready to be properly fiber glassed and painted. Also each panel has like
four 3 inch cracks from the edge inwards, lame i know.
As you can see in this picture, They are turning out rather nicely I think. The
passenger window handle is just floating there seance the spots to bolt it down are
kinda well... not there. The little tweeter will be moved about 4 inches to the left
to the flat section. Its current spot is horrible and dose not fit well, so that hole will
be fixed in the process.
This is all I have for right now, I'm waiting on a nice hot day before I start the painting
and fiber glassing. This will probably be a slow log but oh well.
