1992 mx3 gs vibration HELP!!
dammitcam
Post by dammitcam »
ok i have a 1992 MX3 GS 5spd i just replaced the axle and it wasnt the problem when you get going the car vibrates really bad while in gear however when you put it in neutral it stops or when you slightly turn the steering wheel to the left i was wondering what on earth it could be because the guy i got it from said the tie rod ends were just done and i doubt the blown rear struts would make it do it
newdriver92
Re: 1992 mx3 gs vibration HELP!!
Post by newdriver92 »
cv joint? i had the same issue and it was my cv joint
worklog viewtopic.php?f=46&t=77147
other pics of the adventures me and the car have been on http://s1082.photobucket.com/home/newdriver92/index
Ryan
Post by Ryan »
Does it also happen when its not moving?
I suggest checking your wheel nuts if its only when you're moving... its happened to more than one person. Aluminum wheels will unwind the lugs if you only finger tightened them.
If it happens when you're not moving, I'd look at engine mounts. If one rotted out, the engine could vibrate steel on steel, causing weird things...
