power window and sunroof not working
hey my mx3 power window on passengers side not working and sunroof either i also need the kick panel fuse box diagram aswell what do u think could be the cause ice checked all fuses
jmdearras
Re: power window and sunroof not working
If the driver's side window works, the fuse for the windows is ok. Be sure the "enable passenger window" switch is in the correct position on the driver's side control.
Skylight is probably a seperate issue. The switch itself seems pretty prone to failure, not distinctly clicking when you rock it.
Jim
Jim
