TDC
Andy2486
TDC
Post by Andy2486 »
i put a new disty in now i have to tdc it what is the easiest way to do that?
Re: TDC
Post by wytbishop »
Your distributor can only be installed in one orientation. when you put the new one in it will be int he exact same orientation as the old one was. There is no need to find TDC if you're just pulling the old disty and putting on a new one.
When it comes to setting the timing...that's a different question.
