Hey everyone. I have a question about the wiring harness in my 93' mx3 GS. I am getting ready to install my MS tomorrow morning, but I'm not sure if it is going to work. I got my ms(deluxe with option of coilpacks) from jordan's bb#5 from probetalk, seen here http://forums.probetalk.com/showthread.php?p=1923109991" onclick="window.open(this.href);return false;
My question is, is the wiring in my mx3 the same color code and pin out as a 93 mx6/pgt, because that is what I intended to put it on at the time, but have since then gotten my 3.
I have tried searching, both here and probetalk, but I can't find anything. I'm sure it's there somewhere I'm just terrible at searching. So PLEASE don't just post a reply saying search because that isn't going to help me.
Thank everyone in advance for any help.
93 mx3 wiring & ms
93 mx3 wiring & ms
1993 Ford Probe- R.I.P.
1993 Mazda MX6- Heart of a Ford soul of a MAZDA.
1993 Mazda MX3-T, yeah it's boosted.
Re: 93 mx3 wiring & ms
Nevermind, I found the answer, thanks anyways...
- marcdh
What was the answer? Some of mine seemed different IIRC. You get your coilpacks running? What packs did you decide to get?
View Worklog
View Worklog
The color code on the wiring is different between the 3 and mx6/PGT. A friend of mine who was helping with the install found a pin out of the ecu so we want off that. I haven't gotten my coil packs yet, so it's set up for distributor with the the option to go to coilpacks later. my issue was that my tach signal wire came disconnected so my ms wasn't getting a reading. now I just need to fix my leaky injectors...
