How-to DIY; 2 pot brakeupgrade
This might work for you MX3 people/ EC shares the same hubs as BG
Its too dark to fit this to the car, so no car pics
This ONLY applies 4 stud BG or BA models, GTR BG unknown, BA V6 will need some playing with different rotor sizes
So far i have found two options for this upgrade
one requires cutting of stuff
the other is bolt on
first the parts for option 1 ( No cutting of stuff)
BA V6 hubs complete
BG 4 cly 4 stud wheel bearings and 4 stud centers x 2
Rotors; Your choice of either Slotted/drilled BG GTX/ Astina GT rotors or NB8 MX5/Miata rotors
Calipers; BJ series wagon Subaru Legacy GT turbo (2pot)
Brake brackets; Mazda GD 626/TX5/Probe
Brake pads; as above, but use some Bendix DB1114 or something better than OEM
Brake lines; your choice of either OEM/Braided etc for BG models
First Push out the V6 5 stud Center, push in the 4 stud center
Paint/bling up the calipers from the Subi/Mazda combo
Take note of the numbers on the caliper " AD602T " this may have changed during the Subi models, but you need the one with 1 bolt , not 2
the orange brings out the color in my eyes , best of all NO cutting , just bolt it to the V6 hubs
drop new pads in
Fit new rotors, and bolt together
removal of old setup from ya car, Bolt in the above setup, check steering arm lengths are ok, bleed them brakes, run/ bed pads in ,, DONE
Option two (cutting, swearing, beer/bourbons, & time)
Parts for Option 2
BA V6 hubs complete
Calipers; T series Mazda Millenia/Xedos 9 S/C or 2.5 V6 (2pot)
Brake brackets; As above
Brake pads; as above, but use some Bendix DB1326 or something better than OEM
Brake lines; your choice of either OEM or Braided etc for BG models
Take note of the caliper cast numbers "AD43T" and 2 bolt arrangement
You need to cut back this much off the caliper bracket, tiny amounts off the hubs, casting line was in my way on 1 hub, other was ok
The bolt holes in the V6 hub needs to be drilled out 2mm to fit the millenia bolts, 14mm i think? i didnt do that bit
the dust sheild? also needs a tiny amount chopped off, 2mm as it hits the corner of the bracket
Strangely but there is NO overlap on the Millenia pad when using stock Astina GT rotors???
Passes the 14" wheel test, i started to laugh when this fitted
drop new pads in
BA V6 hubs complete
drop new pads in
Parts for Option 2
BA V6 hubs complete
drop new pads in
SOLD 1991 Mazda Astina GT, BPT,161 WkW @ 9psi, & 102wkw N/A built motor with LSD
1996 ST205 Toyota Celica GT4, big brakes, massive power
worked KL-ZE 220whp in the build, possibly for a 323 or MX3/Eunos
- hotsiit
Re:
I agree, I originally read/saw this on clubprotege...thanks for sharing it here...something else to add to the never-ending "to-do" list.Custommx3 wrote:Nice writeup! thanks!
1993 Mazda MX-3 RS-Turbo
1993 Mazda RX-7 touring
1983 Mazda RX-7 GSL
1987 Jeep Comanche
1983 Mazda RX-7 GSL
1987 Jeep Comanche
- tehbrookzorz
Re: How-to DIY; 2 pot brakeupgrade
I want to hear how this works out; improves braking on our cars. Worth doing if you've already upgraded to something like hawk hps?
Cody
- jaydog5678
What is the diameter of the rotors? Same as the Mx-3?
the rotors pictured are 257mm stock's
ive got to get around and buy some 270mm ones
wait aren't mx-3 rotors stock 254? so moving up to a 257 doesn't seem worth the work, but you mentioned not having the 270s yet. can you fit 270s in there with pads that will cover the face of the rotors? if so then it seems worth it. The hard part would be getting the knuckles here..... please please give us some info especially have you driven on these yet?
ideally i'm looking for something between 280-305mm but i'd be willing to move to 270mm if it was two-pot with the pads making a lot of coverage... and how is this not a sticky creating more discussion?!
ProjectMx
My BP and AWD build thread
Cardomain
93 Escort GT daily driving
Cardomain
what kind of car is the ba v6 ? and do we have them here in the US?
any specs on the calipers??
I think this is the car, its a Mazda 323f BA (1994-1998)
http://www.club323f.com/content/ba/cars ... a_sylvain/" onclick="window.open(this.href);return false;
1997 1.6 16v DOHC uk spec gs, 17" wolfrace triad, 2.0l probe s/s header magnaflow high flow cat, powerflow custom catback, CAI, zx2 struts w/ -40mm lesjofors springs
http://www.uk-mx3.com" onclick="window.open(this.href);return false;
If we can fit the calipers and the brake caliper braket with those mods and the wheel hub and bearing r also interchangable..... I wonder what it would take to fit a set of ksport brake kits...
- marcdh
You know you can get them here? Clearly not cheap though!
http://www.jeroentje.nl/index.php?page= ... d=70100701
View Worklog
View Worklog
well the reason i was thinking about the probe/mx6/626 kit is because i thought they make front and rear upgrade while there isnt a rear upgrade for mx3 rears...
- WhiteFinish
