Dual Sub Hookup Question
- Bling Bling
Just purchased 2 - 10" Infinity Reference subs and box off a local guy for $140 Cdn. I guess they can handle around 500 Watts each. My question is should I run a two channel amp...one channel to each sub or runa mono amp and parallel the subs together? What is the advantage of either hookup? Which is more efficient?
Stacy Whitrick
MX-West Calgary
http://www.cardomain.com/ride/1335558 UPDATED June 6,07
94 GS, Green Envy Pearl QUESTION: Does my car fit the RICE category?
MX-West Calgary
- lowridah313
It all depends are the subs DVCs? Whats the resistance of the voice
coil(s)? Is the amp 2 Ohm stable? Can it be bridged?
Representin' the THRE3:TH1RT3EN
'02 Nissan Xterra SE, atx, 4x4, 32's
'92 Geo Tracker atx, 4x4
Feedback http://mx-3.com/phpBB3/viewtopic.php?f= ... 54&start=0" onclick="window.open(this.href);return false;
m0rpheus666
If the amp can be bridged mono and is 2 ohm stable, running parallel mono will sound hella better because it is pushing the max power that the amp can put out to both speakers. I currently have 2 12" sony xplods hooked up to a 820 SPL amp. it is unfortunately not 2 ohm stable but still is louder than hell. I would recommend pointing the speakers towards the back of the car, this allows the sound to resonate alot better and give you deeper, richer sounding bass.
- Bling Bling
I haven't bought an amp for them yet. And I will pull a speaker this weekend to get the resistance for that sub. I figured the general concensus would be run in parallel but wanted to check with the audiophiles out there.
Stacy Whitrick
MX-West Calgary
MX-West Calgary
m0rpheus666
Suresperance
i had the exact same speakers in my old car. i had then hooked up to a rockford fosgate 2chanel amp and ran them in paralell i tried both ways and deicded that paralell sounded better. also i had them over a year with no problems so you should be alright with reliablity.
P.S. good snag on those subs best ones ive ever had till i got my dual 12" eclipses
