Getting BOV operation while my Boost gauge is in vac???
XxantwawnxX
Post by XxantwawnxX »
im getting BOV operation while my Boost gauge is reading very slight VACume like 1 or 2. Is my gauge off alittle bit? its an autometer i think : (
MX3ze@7psi
Post by MX3ze@7psi »
my blow off valve goes off even though I'm not boosting. I guess its normal. You should begin to hear the turbo spooling if your that close to boosting.
MX3 KL-DE, probe/mx6 ebay turbo pipes, T3/T4 50 trim @ 8psi, millenia injectors, SAFC2, intercooled,Greddy RS BOV, turbonetic 38mm external wastegate. Wisco 9.5 forged piston, millenia S rods, and high performance rings coiming in soon. Shooting for 400whp this summer.
XxantwawnxX
k thanx.
BuGS
Post by BuGS »
Thats normal. What is awesome when you do a low load spool and you get massive wastegate flutter.... that sounds sweet...
XxantwawnxX
yea ive gotten that before : P
Return to “Forced Induction”
